Injector Major Problem please help
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Hey guys i feel so stupid right now a friend and i were doing a head gasket replacement and everything is back to normal only problem is when we got to the Injectors before we took them off we marked them with black tape to the injector plug. Well after it being down for 5 days the tape came off when we were taking other parts out. I was wondering if you guys know the mark on the injector plugs that says were it goes. We tried it and when we turned it on we had a miss. So we took it off and now we are at a stop. We are about to go look at another camaro and see so we can match it up.... its a 1992 camaro 5.7l L98 thanks glad for any help
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Injector Major Problem please help
TPI right? The injectors are batch fire. that means that there are 4 injector wires to one wire. So here is how it works. all injectors one side fire and alternate from side to side. In other words, left,right,left,right,left,right.
