Inspecting a Roller Lifter.
Old Jun 12, 2011 | 07:46 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Does anyone know how to re-install the piston back into the lifter housing? I tried to push down on the piston but there is so much resistance that I cant put in the wire holder. Any help or advice will be appreciated.
Old Jun 12, 2011 | 11:51 PM
Guest
Guest
Posts: n/a
Re: Inspecting a Roller Lifter.
Ya gotta get all the oil out first.
Old Jun 13, 2011 | 12:14 AM
I believe all the oil is out already, unless there is more deeper inside the lifter. The pictures show the max that the piston will drop inside the lifter. Theres gotta be a way to get that sucker in there.
100_2216.jpg?1307942023
Old Jun 13, 2011 | 08:55 AM
Guest
Guest
Posts: n/a
Un-bend a paper clip, and use that in the center hole of the pushrod cup. That'll let the last of the oil out.
Old Jun 15, 2011 | 12:45 AM
ronnjonn,,, You are the BOMB!!!! It worked man. Thanks so much man. So what would be the best way to clean out these rollers?
Old Jun 15, 2011 | 09:07 AM
Guest
Guest
Posts: n/a
About all you can do is disassemble them, clean them with lint-free rags and carb cleaner, or brake cleaner, then lightly lube them, and reassemble them using the paper clip.
I've done it once, it took me most of a Saturday, but seemed to work out just fine.
Lbibb
May 5, 2016 12:00 AM
KO1
16
Oct 15, 2015 05:00 PM
bjpotter
Oct 4, 2015 07:48 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
