92 RS 305 TBI. Runs Rich, wont pass inspection
Hey everyone. I have a 1992 RS Camaro 305 TBI that I am trying to get inspected and registered. The car runs a little rich and I wanted to know everything I should be looking at in order to get the car to run efficiently enough to pass inspection so that I may be able to get it registered.
I have replaced the following;
plugs
wires
cap and rotor
02 sensor
I have also ran injector cleaner through as well. What else should I be looking at? (MAP Sensor? EGR? ect...)
Thanks for the help!
plugs
wires
cap and rotor
02 sensor
Car: 1991 camaro RS
Engine: 408 Stroker
Transmission: 4L80e
Re: 92 RS 305 TBI. Runs Rich, wont pass inspection
there's a lot of things that can cause that but some ideas, Mass airflow, Spark plug not gap'd correctly. Does the car have any aftermarket stuff?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You may need to get to the injectors and check them. Fingers crossed the cleaner works but you want to at least check resistances.
Yea I figured I may have to do that. I want to make sure I check all areas to make sure she is running as good as possible. Thank you all for your help and if any other ideas pop in your head please let me know. Thank you
