TBI Question
Old Jun 17, 2011 | 10:15 PM
redcamaro1988's Avatar
Car: 1988 Chevy Camaro
Engine: 305 TBI
TBI Question
I am planning on doing a mild build on a 350 2 bolt. I was wondering if I can reuse the TBI off my 305? Should I get a new TBI set up or go carb? If I go carb what can I do to reuse my stock fuel system? Thanks guys!
Old Jun 18, 2011 | 06:49 AM
ex-x-fire's Avatar
Re: TBI Question
If you put a 305 tbi on a 350, it'll run but it'll run lean. Get the 350 injectors or the whole tbi from a junkyard.
If you use a carb. w/ the electric fuel pump you'll need to add a fuel press. regulator as carbs run off of 5psi or less.
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
