white smoke
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: white smoke
your burning oil or your burning coolant. check your heads for cracks. do you have any loss in compresstion? when dies this happen? cold... hot?
Re: white smoke
As i said its random... the car will be fine and the check engine light will come up outta nowwhere... the only thing thats really an indicator is tje smoke and a slight loss in power
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: white smoke
Have you checked your coolant and oil?
Verify your fluid levels. You should also check if the coolant is still green and clear. If it's dark or murky that usually means you have oil in it. Check the oil too.
Whenever I've blown a head gasket it was just full on smoke screening. Maybe it's just a slight leak.
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: white smoke
One thing you could do is mark your reservoir with a marker and see if you are loosing coolant this way. I did it with a 350 tbi, and sure enough I had a cracked head. The oil looked good, the coolant wasn't contaminated, but I had a small crack in one of my heads, causing me to loose coolant.
Pac J
May 17, 2020 10:44 AM
