Need a motor
Old Jun 19, 2011 | 10:49 AM
EMT Drexler's Avatar
Car: 1988 Camaro
Engine: 2.8 V6
Need a motor
I am in need of a 2.8 V6, found out I blew mine, I am in NC, anyone know of a place to get a cheap engine ?
Old Jun 19, 2011 | 03:14 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Need a motor
Junkyard maybe? Craigslist? Either way it would be wise to have the motor remachined. And you already have a block. What happened to yours? How is it blown?
Old Jun 19, 2011 | 06:47 PM
Car: 1988 Camaro
Engine: 2.8 V6
Re: Need a motor
We did a compression test, all the cylinders are around 90-95 pounds, but #6 is at 50, was told i had a dead cylinder
Old Jun 19, 2011 | 09:19 PM
Guest
Guest
Posts: n/a
Re: Need a motor
Try to find a 3.4L from a '93-'95 F-car. Be sure to get the injectors and flywheel or flexplate.
It's a painless upgrade.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
