recurving cc distributor?
Old Jun 22, 2011 | 12:43 AM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Hey guys,
the engine in the car has a slightly higher compression ratio than the lg4 that came with it. I hear your supposed to limit the mechanical advance or something to balance the compression. But don't the computer controlled distributors take care of the timing anyway? I'm kind of confused if I need to get an advance kit or not. Also my distributor doesn't have a vacuum canister, do I need one of those? And if so do I just connected to a port on the carburetor?
Old Jun 22, 2011 | 02:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: recurving cc distributor?
If the dist is computer controlled then any timing changes can only be made by changing the timing settings in the computer program
Mech advance and vac advance are only used on non CC carby engines
Old Jun 22, 2011 | 07:09 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You've still got the ccc-qjet on there?
Old Jun 22, 2011 | 11:17 AM
0pyders's Avatar
yes I have the cc quadrajet on. So I won't have to mess with the distributor, but the computer? Or would the computer fix the compression difference for me?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
