removing TPI runners
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: removing TPI runners
Would you take $20 for them? They look like nice fixer-uppers.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
That's the last time those runners will trash talk.
So did you drop something on the motor? Most of the denting looks to be the topside.
Transmission: 4L80E/4L80E
Some day a clean set of factory runners will be worth about $900.
Car: 1991 Z28 Vert
Engine: 305ci
This was a result of my TPIS MiniRam install last weekend, figured they wernt going back on so why bust my knuckles gettem off. Only had to bust up the passenger side for some reason I couldent get a scocket on the bolts. The other side came off easy.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Shouldn't have to do that to remove TPI runners. I have no issue removing and installing my TPI system, and i've removed and installed it 4 times in a year. So I don't think bashing them up is justified.
But I imagine it was nice taking your anger out on something, bashing is a good stress reliever.
Car: 1991 Z28 Vert
Engine: 305ci
Yeah, this was my first.. an last time removing them, Have no idea how, they were all dented up any way, prob should have takin better care but I was getting pissed at it. hahaha
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
