PLEASE HELP!! im lost
Old Jul 1, 2011 | 11:57 PM
jbmillenium's Avatar
Car: 91 ws6
Engine: tpi 350
im trying to get this 91 ws6 on the road again and there are several unplugged wires under my dash, im trying to find out what they are, one has a vacuum line on it and one under the steering wheel is simply cut, i think the cut one is for the air bag. please help im trying everything to get this car running and im sure all this stuff unplugged is not helping.
the one in front has a vac line on it
and the little one in the backround with the purple wire is unhooked to
Old Jul 2, 2011 | 12:00 AM
Car: 91 ws6
Engine: tpi 350
Re: PLEASE HELP!! im lost
please anybody, im hopefully going to get this car going this weekend.. 4th of july cruises
Old Jul 2, 2011 | 12:04 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
bump, I hope you get some answers
Old Jul 2, 2011 | 12:19 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The loom with the vac line in it, I'm guessing is part of the cruise control.
Old Jul 3, 2011 | 09:40 PM
Car: 91 ws6
Engine: tpi 350
this was the answer i got in the other forum. thanks for trying to help
Pocket
Car: 92 Firebird
Engine: Supercharged 6.0
Transmission: 4L80E
Yellow mean airbag. Connectors, tape, anything yellow, dont mess with. No, it wont prevent the car from running
The harness with the large vacuum hose is cruise. Look over the top of the column for the mate. Hose connects to the right side brake switch on the barb
Large square is a relay socket for some option you dont have. Theres on in the camaro RS in my garage too going nowhere
2 row connector bolted to the fuseblock is the ALDL. Hook your scan tool up to this or use a paperclip to ground out two pins to pull the trouble codes if the MIL comes on
2 pin Yel/PPl connector in the back is an inline connector for the clutch safety switch on manual cars. Yours is auto so dont worry about this one either
ZZ3Astro
Aug 13, 2019 12:57 AM
djmarch
May 8, 2016 11:32 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Jynx88
Oct 4, 2015 08:19 PM
3.8TransAM
Sep 27, 2015 08:37 PM
