Forget where this bracket goes
Old Jul 3, 2011 | 09:55 PM
3GEN90's Avatar
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
Hi Guys!
Just installed my hedman headers in my 1990 formula (305 L03). Forget where this bracket goes. Anybody know and can take a pick of where it goes?
Thanks!
Old Jul 3, 2011 | 10:02 PM
twistedfaith17's Avatar
Car: 92 rs
Engine: 350 tbi
Transmission: 700-r4 with shift kit
Re: Forget where this bracket goes
looks like the bar that goes from the header bolt to the back of the pollution pump/ac or something in the area
Old Jul 3, 2011 | 10:09 PM
3GEN90's Avatar
Axle/Gears: 3.08
Thanks...if so...guess I don't need it since the smog pump is out. Still if someone can send me a pic where it is actually bolted that would be great!
Old Jul 3, 2011 | 10:17 PM
Car: 92 rs
Engine: 350 tbi
i would but i left it off mine when i put my edelbrock cermic headers on, i don't think it would fit with them but i'm not sure
Old Jul 3, 2011 | 10:31 PM
3GEN90's Avatar
Axle/Gears: 3.08
Thanks! But just for piece of mind (you know when there is one bolt left and jsut cant seem to find where it goes) if someone still has no headers, a pic of its location would ease my miind that I'm not leaving off something way impaortant.
Thanks again for your reply!
Old Jul 3, 2011 | 10:46 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
alternator to block i reckon
Old Jul 4, 2011 | 11:34 AM
3GEN90's Avatar
Axle/Gears: 3.08
No..that one is on. So is the a/c bracket. My a/c is on the pass. side.
Old Jul 4, 2011 | 12:10 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That brace normally goes from the bolt on the back of the AC compressor near the bottom right in front of the exhaust manifold and down to an exhaust manifold bolt It may no longer fit with the headers, IDK? If you still can't figure it out, get me your email address and I'll get you a pic today or tomorrow
Bent end to the AC side
Old Jul 4, 2011 | 07:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It will still fit - what you need is a steel spacer from Home Depot in the hardware section, and a longer header bolt (or one of the original bolts). Put the bolt through the bracket, through the spacer, through the header, and into the head.
Old Jul 4, 2011 | 07:48 PM
3GEN90's Avatar
Axle/Gears: 3.08
Can you send me a picture, or post one? My a/c is on the pass side.
Thanks!!!
Old Jul 4, 2011 | 10:14 PM
Car: 1992 RS
Engine: Carbed 350
Sorry - don't have one - no A/C here anymore. But it's just as simple as I stated. Lowes/Home depot have the perfect size metal spacer (about 1 1/2 inches) in the hardware section, hard to miss, they only carry a few sizes - just take a header bolt with you to get the right inside diameter. Then buy a longer bolt same size/thread as the header bolt that's long enough to go through brace, spacer, header flange, and into the head.
Old Jul 5, 2011 | 06:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check pics 2 and 3 in post #16 of the following link for pics of the brace in question (manifold, with header spacer, to rear of compressor):
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Jul 5, 2011 | 08:37 AM
3GEN90's Avatar
Axle/Gears: 3.08
JamesC
This is exactly what I am looking for!
THANKS ALL!!!!!!!
Old Jul 5, 2011 | 02:02 PM
JamesC's Avatar
As requested. There are two green wires and one blue.
JamesC
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
