idle problem help
Old Jul 4, 2011 | 02:35 PM
j maro's Avatar
Car: 85 z28 iroc
Engine: 305 tpi h.o
idle problem help
Got a 85 camaro 305 tpi wondering if anyone noes why my car idles hi when started ,Around 1700 rpm, then takes about 15 to 20 sec. the idle down. That's cool when i start it when it's cold but even when it warmed up it still does it . Just a little annoying. Anyway to fix it or adjust something.
Old Jul 4, 2011 | 09:29 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: idle problem help
Sounds pretty normal to me. If anything, it could be your IAC solenoid, but I think you are ok from what it sounds. You can always check it. If you have a manual for the car, it tells you how in it.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
