what cam to buy
Old Jul 4, 2011 | 09:48 PM
the fox's Avatar
what cam to buy
hello i just got a l48 from a 74 vette to put in my 85 camaro i have it all apart now replaceing all the leaky gaskets so i thought it would be a perfect time to replace the cam but dont know what one to get. I m not looking to gain crazy horse power but would like a better sound. the engine has 128 000 k and is stock. any info would be great
Old Jul 4, 2011 | 09:53 PM
Robby12's Avatar
Re: what cam to buy
Id go with the comp cams 268h or if you want a little more the xe268h
there nice sounding cams not to mild and not to wild gives you plenty of vacuum at idle to run power breaks and other accessories
Old Jul 4, 2011 | 11:52 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: what cam to buy
Will you be running a performance intake like an air gap,headers etc.?
I would run the old comp cams 280H in there its A very nice cam does not cause vacuum problems and other associated problems...... Not dismissing the 268H at all its a great grind aswell.
Old Jul 5, 2011 | 09:04 AM
Guest
Guest
Posts: n/a
Re: what cam to buy
With those 1.94 / 1.50" valves, you need a dual-pattern cam. And even if you get the heads milled 0.030", you still have under 9:1 compression, assuming original-style dished pistons.
Considering these, I'd say the XE268H would be the best compromise.
Old Jul 6, 2011 | 08:49 PM
the fox's Avatar
Re: what cam to buy
just headers and a edelbrock performer intake
Street Lethal
Apr 30, 2019 12:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
