Timing cover confusion
Old Jul 7, 2011 | 10:20 AM
Toyojake's Avatar
Car: 83' Z28; 89' S-10; 04' Jeep
Engine: Z28: 87' 350
Axle/Gears: Stock 2.93's
Hello all. My 83' Z28 has a 1 piece rear main, roller motor from a 1987 K5 full size blazer. The timing cover on this one is trashed and leaking pretty badly. I have 3 other timing covers from all 86-older hydraulic 2 piece motors. The timing tab on the cover on my engine right now is an aftermarket bolt on one, not sure if its in the right place or not, and the other 3 covers I have; have different locations for the timing tab. One cover is from a 74' 350 SBC, one is from an 85' 350 SBC and the other is unknown. I'd like to know where I can find the correct timing tab position for the roller motor in my car and which timing cover I can use.
Thanks in advance,
Jake
Old Jul 7, 2011 | 10:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing cover confusion
You can use whichever cover you like, and just make a new TDC mark on your balancer if it's not in the right spot.
Old Jul 7, 2011 | 11:16 AM
Toyojake's Avatar
You know, I didn't think about that. Lol. Thanks man.
Old Jul 7, 2011 | 11:26 AM
Toyojake's Avatar
Alright, so after a few quick searches on making timing marks.. have never done that before. Is it really as simple as marking TDC at 0* on the other timing tab or am I missing something?
Old Jul 7, 2011 | 12:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Set it to TDC and put a mark on the balancer under the 0 mark on the pointer.
Old Jul 7, 2011 | 12:42 PM
Toyojake's Avatar
Thanks, Apeiron
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
