Help Needed: Heated O2 Sensor
Old Jul 7, 2011 | 01:31 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I just bought a Bosch 13077 heated O2 sensor to install in my car. I think $25 is kind of ridiculous to pay for the harness that is made for our vehicles with a heated O2, so I planned on hooking it up myself using the 1 wire harness from the old O2 sensor, spade connectors and heatshrink. However...
I can't find anywhere which wire goes to what on this thing. I have two white wires and a black wire. I know one wire is for the signal, one is power to the heater and one is heater ground, but I can't find ANYWHERE which wire goes to what. The 3 wires on the harness are labeled A, B and C but I still can't find anything that points to the function of each wire.
Could someone please point me in the right direction?
Old Jul 7, 2011 | 02:03 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Help Needed: Heated O2 Sensor
2 whites are power and ground...black signal
Old Jul 7, 2011 | 02:20 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
The install is pretty simple Ive done it on my car. Remember that the power wire needs to go to an ignition on power source.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
fonzie85
Aug 13, 2015 11:50 AM
