Self aligning and non-self aligning roller rockers
Old Jul 8, 2011 | 11:44 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Whats the difference between the 2 roller rockers? How do self-aligning self align themselves?
Old Jul 9, 2011 | 01:46 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Self aligning and non-self aligning roller rockers
This refers to the technique used to keep the rocker tip on the valve stem tip. Self-aligned have a little tang or projection either side of the rocker tip/roller, which locates the rocker on the valve.
Non self-aligned uses either: guide plates, or narrow slots in the head. Both these techniques act on the pushrod, and thus keep the rocker in place.
You can only use one of these techniques, or they may cause a bind.
Do a search for more details, there is tons of info on this.
Old Jul 9, 2011 | 07:29 AM
Guest
Guest
Posts: n/a
Self-aligning are sometimes called rail rockers.
I recall reading where the rail rockers are all closer to 1.5:1, while the older rockers are actually closer to 1.45:1. This seems plausible to me.
Old Jul 9, 2011 | 09:07 AM
grumpyvette's Avatar
http://forum.grumpysperformance.com/...+rockers#p7458
in this picture the self aligning rocker is the center one with the raise ridges that keep in centered on the valve tip , the two end rocker require guide plates
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
meeklay812
Oct 1, 2015 03:46 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
