Is it an Engine knock?
Old Jul 4, 2011 | 09:20 PM
SRichardson868's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
Ok so my 1991 camaro rs 5.0 tbi 46,000 has been making this knock sound and it sounds like it comes from right under neath the valves. I'm worried because now i'm nervous to give it some gas and let the rpms go up....is it the valves or the piston? The sound goes away when i drive but then when i get off a highway that i been on for more then 5 miles i can hear it again. Will the stp combustion stuff will help could it be spark knock PLEASE HELP!!
Old Jul 4, 2011 | 09:33 PM
Robby12's Avatar
Re: Is it an Engine knock?
Give it a oil change with some 5w-30 and use some of that thick lucas additive that would cover up the noise if it is a lower end or rod knock and will give you more time till it comes apart
It could be that the rockers need to be adjusted but if its ''under neath the valves'' like you say its most likely a lower end knock
How many miles are on the engine?
When was the oil changed last?
Old Jul 4, 2011 | 09:49 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
the oil was changed about 1 year ago but i havn't put alot of miles on it and im constanly adding oil (had a small leak fixed it) it all together has 46,567 miles on it and is the knock fixable how about the STP stuff help? how about spark plug change?
Old Jul 4, 2011 | 09:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
valve lash makes a ticking sound, bottom end problems make a knocking sound.
If it's a ticking type sound, I'd adjust valve lash before I started dumping in fix-all oil treatments. If ticking persists after adjustment, might be a bad lifter (warrants removal on intake to check lifters and cam lobes).
If it's a knocking, then yes, might look into adding a oil treatment.
Old Jul 4, 2011 | 10:00 PM
Robby12's Avatar
pull out the spark plugs and read them see how worn they are and how the air/fuel is on cylinders you think may be the cause of the knock,If the STP stuff you are talking about is that real thick stuff you add to the oil ya it will work im just use to using the lucas any auto part store will have it here is a link
http://www.lucasoil.com/pages3-2/FAQ this stuff will quite down any rod knock if that's the problem it will also extend the life of your engine i use it in diesel trucks
Old Jul 4, 2011 | 11:40 PM
affliction1's Avatar
Car: 89 chevy camaro rs
check your timing,could be to advanced,causing detonation
Old Jul 5, 2011 | 07:23 PM
Drac0nic's Avatar
Could be a rattle or exhaust leak too. If it's only at start up it could be a drain back valve too. What's your oil pressure gauge telling you?
Old Jul 6, 2011 | 09:43 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
i think its a knock but it still has its kick it can put you back in your sea cause of the mods
Old Jul 7, 2011 | 12:22 AM
retard the timing a lil 2-4 degrees,and see if it gets better if not turn it back,mark on dist shaft and intake with sharpie before you turn it so you can have a referance point,
Old Jul 8, 2011 | 06:18 PM
torque_is_good's Avatar
a lot easier to slap in 8 gallons of premium fuel
8 gallons times 20 cents per gallon difference vs the cheap stuff= $1.60 extra cost
Old Jul 9, 2011 | 12:50 AM
Old Jul 9, 2011 | 10:44 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
See if you have a drippy injector
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
