Valve seals. Replace or buy new heads?
Old Jul 14, 2011 | 08:44 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
The valve seals are starting to go in my 87 305 camaro. Anyone have an idea of how much it would be to have them replaced and is it worth or should I buy new heads. Any opinions on a decent pair of heads for a carb'ed 87lg4 that aren't too pricey?
Old Jul 14, 2011 | 09:49 PM
Guest
Guest
Posts: n/a
Re: Valve seals. Replace or buy new heads?
You should already have the good '081 heads. The only upgrades are either milled Vortecs, or TFS 175 cc aluminum heads. The Vortecs will require a different intake manifold to match.
But no point doing them until you do the basics, like gears, headers, exhaust, subframe connectors, et cetera.
Just do the seals for now. And fresh springs. You can get new "LT1 Z/28" springs for like $2 ea.
Old Jul 14, 2011 | 11:22 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
And honestly the valve seals really arent that big of a deal. Unless you're blowing out massive amounts of oil smoke on deceleration it's not really worth stressing over.
Old Jul 14, 2011 | 11:44 PM
StringRust's Avatar
I have everything u mentioned except the SFCs. Headers to 3”inch exhaust, 3.73 posi, holley carb and intake manifold.
No smoke on decel. Ill look into seals and springs. No rush being I'm broke
Old Jul 15, 2011 | 10:56 AM
mswen22780's Avatar
Car: 1985 Chevrolet Camaro Z28
Doing seals is not that bad, you don't even need to pull the heads. Retrofit a Compression tester to fit an air compressor to pressurize the cylinder and to keep the valves up. Remove locks, springs and seals and reassemble.
Old Jul 15, 2011 | 07:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've also read where folks just used clothes line size rope, and stuff it in the spark plug hole until the cylinder is filled with rope (keeps the valve from falling) while replacing the seals.
But - being broke - don't sweat it. It's actually not a bad thing to have a tad of oil in the cylinder (although the puff of smoke is bothersome) - keeps thiongs nice and smoothly lubed!
Old Jul 24, 2011 | 03:23 PM
tocoso's Avatar
Car: 1988 GTA
Transmission: T-5-manual
Axle/Gears: 3:45
I have a set of professionally rebuilt / never installed 081 heads that don't have a engine for them anymore. I'd sell them cheap. Let me know if your interested.
Todd
NBrehm
Aug 25, 2015 11:49 PM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
