355 TPI Roller rocker noise
Old Jul 15, 2011 | 01:58 PM
JeffK's Avatar
1990 Corvette 113 heads refreshed less than 200 miles ago, 1991 Vette block bored .30, Mahle hyper pistons, Lt4 valve springs and keepers, Lt4 hotcam, Crane gold non-SA roller rockers (part# 19002-16), 7.2 hardened pushrods, isky adjustable guide plates, hedman elite headers with Percy's deadsoft gaskets.
I've been messing with this thing for nearly 6 months trying to get rid of what sounds to me like a valvetrain noise. It started after I had the heads refreshed which included new seats, install of springs, valves checked and ground and pressure test. While I was trying to figure out this noise it started blowing oil out of the valve covers so I had the "new" short block built. I reused the heads since I had the $$ into them already. Guy that built the block also installed heads, set preload, etc.
Installed the "new" engine thinking that I would never hear that annoying noise again. NOT! I know that the rollers are going to make some noise but I don't think it's supposed to be this loud.
http://youtu.be/mVYujR0lgO0
I looked at the valve stems and it looks like the rockers are contacting in the right place there so I don't think it is a geometry issue. I guess it could be a header leak.
I don't know, I'm stuck and tired of throwing $$ at this damned car.
Any suggestions?
Thanks,
Jeff
Old Jul 16, 2011 | 12:07 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: 355 TPI Roller rocker noise
Are you 100% sure the lifter preload is adjusted correctly?
Old Jul 16, 2011 | 08:50 AM
JeffK's Avatar
I adjusted the preload by watching the intake valve on one cylinder, after it had opened I continued turning until it was atleast 2/3 closed then I adjusted the exhaust. Then I rotated engine until the exhaust was just starting to open and I did the intake.
Old Jul 16, 2011 | 09:45 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Roller rockers are louder. If its to loud 4 ya put your stockers back on and see if you like it better.
Old Aug 5, 2011 | 06:32 PM
semiller26's Avatar
Car: 1986 Trans Am
Did you ever find the cure to your noise?
Old Aug 10, 2011 | 02:37 PM
JeffK's Avatar
I have.
I had to use ISKY adjustable pushrod guides and adjust the rockers with the engine running. Yes, they are still louder than stock. That wasn't my real concern.
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
