Enige Seized up
Old Jul 18, 2011 | 03:12 PM
AFman341's Avatar
Car: 1987 Trans Am
Engine: 5.0L
Transmission: Manual
Enige Seized up
Hello I have a 1989 2.8L automatic Firebird.
I made the mistake of letting a "friend" borrow my car, and he bottomed it out then didnt tell me. My oil pan got damaged and all the oil leaked out over night. When I started the car in the morning and tryed to drive off the engine seized thus shutting the car off.
Now I was wondering if there was anyway to get the engine to turn over and get lubricated, I put new oil in after the engine cooled off and tried to turn it over, It wants to turn over but just needs a little help.
So is there anyway to fix this problem with out taking the engine apart or out of the car? If not I guess I will be learning how to rebuild a engine or doing a engine swap.
Old Jul 18, 2011 | 03:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Enige Seized up
No, if the engine seized up and stopped the car from lack of oil, you won't be able to get it running again until after you rebuild it. Sorry.
The starter won't turn it over, because it's seized up. If you keep trying, you'll probably either break your starter, or the flexplate.
Old Jul 18, 2011 | 03:47 PM
AFman341's Avatar
Car: 1987 Trans Am
Engine: 5.0L
Re: Enige Seized up
Thanks, And theres no way to get it in gear since its a automatic? I was thinking if I could get it in gear then rock the car back and forth it might make the pistons move?
if the only way to fix it is by rebuilding it then I guess nows a good time to learn how to do that lol.
Old Jul 18, 2011 | 04:19 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Enige Seized up
It's siezed up from what happened when it had no oil, even if you could get it started back up, the bearing's will eat themselves alive and it will have more engine noise than ever, then immediately shut off, and be totally screwed. Unfortunately a new motor/full rebuild is in the cards.
Old Jul 18, 2011 | 06:25 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Enige Seized up
Now is the time to find a good 350, and NEVER loan a car to anybody!
Old Jul 18, 2011 | 07:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Enige Seized up
i hope your friend is going to make things right and pay for damages . if not he is not much of a friend . if not willing to pay , contact/explain to your 1st Sgt. . i am sure he can convince your "friend" to do the right thing . advice from an old , old ret. A.F. M/sgt. . good luck .
colton_carlson
Mar 8, 2019 12:21 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
Red Devil
Feb 25, 2001 11:40 AM
