steps for swapping a gas tank
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
i dont have much time to research all the steps if someone could break it down that would be awesome just drop the rear subrame or just the rear end>? and then the exhaust and driveline or what sorry for the messed up post i dont have time now as im late to class thanks
ANY ADVICE IS APPRECIATED
Transmission: 4L80E/4L80E
I've never seen a removable rear subframe in these cars.
Here are the steps I followed:
1) Take off what is in the way of the tank.
2) Take off what is connected to the tank.
3) Take off what holds the tank in the car.
I already had the exhaust off, and had taken out the rear end, so that probably helped.
If you need more details than that, you should probably get a shop manual.
AkDrifted
Aug 17, 2015 07:45 PM
