whats the highest rpm full bolt on l98
Old Jul 19, 2011 | 12:51 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
i might need to play with the goveners in my 700r4 next spring. Whats the highest rpm i can shift at with a full bolt on l98?
At the moment i have a hsr, cai, headers, 3" flowmaster, msd, afpr, pcm for less tune, 3:73, most free mods. Another question, would you guys suggest a set of 1.6rr to make a few extra hp? typically what should a car like this be shifting at. im thinking no more than 5300rpms.
ive been reading about bolt on l98s trying to hit high 12s makes me think after the following i should be low 13s with some nitto drags 12s might be possible.
Old Jul 19, 2011 | 12:53 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: whats the highest rpm full bolt on l98
im also in the process of selecting a good stall speed, if anyone knows what would work well let me know, im guessing around 3k converter.
Old Jul 19, 2011 | 01:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Stall speed depends on the setup. You want maximum torque and still be able to hook if it's a drag strip application. For street cruising my stock 350 responded very well to my 2400 RPM 9.5" converter. Stall flash is depended on the motor output. A converter will obviously flash higher behind a BBC than a 305 due to extra torque.
My experience has been stock TPIs are out of there power range by or at 5000 RPM. Since you have a stealth ram yours might breathe better.
Either way I would throw it on the dyno and check it out.
theshackle
Sep 17, 2020 08:26 AM
355tpipickup
Aug 19, 2015 10:02 PM
355tpipickup
Aug 13, 2015 07:35 AM
gwade12
Aug 8, 2015 08:17 AM
