electric fan 82 z28
Old Jul 20, 2011 | 01:11 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
electric fan 82 z28
anyone know what kind of electric fan i should put in my 82 z28 cfi. ive been looking around but cant really find much i want a dual fan and new not used.
Old Jul 21, 2011 | 01:22 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: electric fan 82 z28
id go with used persnally and save money for better quality,the best fans are in like 97 ford taurus's there duel fans with high and low,heard nothing but good news about them
Old Jul 21, 2011 | 03:16 PM
Lumarus's Avatar
Car: 1982 Z28 T-Top Camaro
Engine: Vortec 355
Transmission: T-5 5Speed Manual
Axle/Gears: Stock Limited Slip
I have a 1982 z28 and wat i did was took a Single electric fan off a 97 Cavalier. Its bigg enuff to fit perfect inside the stock clutch fan shroud. i used tie wire to simply tie it in place snugg.
Old Jul 21, 2011 | 04:16 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
How would you hook this up? Would the taurus fan come on automatically with a fan switch like on the later model camaros? What kind of relay?
Old Jul 21, 2011 | 11:56 PM
wire it with a switch if you want or get painless wiring kit for fans from summit.im sure theres other kits too
Old Jul 22, 2011 | 01:28 AM
You mean a block switch, or Painless wiring kit?
Old Jul 22, 2011 | 05:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I used the mid '90s Taurus fan. From a 3.8L Taurus. They move significantly more air than the aftermarket fans, and are very cheap.
You use a temperature switch that you install in your cyl head. You can use a factory one from a later Camaro (~1992 -- 215*F IIRC?), or in my case, get a Corvette C4 aftermarket one ($20 - 185*F).
Then just wire it up to power through a relay/solenoid, with a fuse, and a hot in run power wire. The temperature switch is the switched ground.
I only wired up the low speed, it keeps my aggressive 350 nice and cool. Although you can put a switch in your car to control the high/low speed if you want.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
