FUEL LINE LEAK
Old Jul 21, 2011 | 12:28 PM
jking239's Avatar
Car: 87 IROC-Z
Engine: 5.OL 305 TPI
FUEL LINE LEAK
I RECENTLY DID THE FUEL PUMP TRAP DOOR MOD ON MY 87 IROC, I CUT ALL THE FUEL LINES OFF CLEAN WITH A DREMEL BUT FOR SOME UNKNOWN REASON ONE OF THE 5/16" LINES CONSISTENTLY HAS A TINY LEAK, ALL THE LINES WERE PUT BACK TOGETHER USING QUALITY COMPRESSION FITTINGS, AND I EVEN REPLACED THE FITTING ON THIS LINE TWICE, BUT THAT DIDNT SEEM TO HELP. SO I WAS THINKING ABOUT JUST USING SOME RUBBER HOSING WITH DOUBLE CLAMPS ON EACH SIDE... WOULD THIS BE A GOOD IDEA OR ANYONE HAVE ANY OTHER SUGGESTIONS? THANKS FOR YOUR HELP
Old Jul 21, 2011 | 01:23 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: FUEL LINE LEAK
Could always replace the entire line that you cut.
Old Jul 22, 2011 | 12:20 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: FUEL LINE LEAK
rubber hose will work they make fue injection rated rubber hose(used them on wifes 97 grand am when i couldnt get fuel filter off without special too)l.works great no leaks just besure to clampthem nice and tight
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
