Replacement heads, which way to go?
Old Jul 22, 2011 | 09:40 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
So my ex girlfriend either blew a head gasket or cracked a head on my 305. The engine smokes like a freight train for about five minutes when I start my car, and I can't keep the engine from getting really hot. My question is, should I buy 305 heads to replace the ones I have, have mine rebuilt, or get something else? Would 350 heads bolt on? I've got a completely stock engine. What would be my best way to go?
Old Jul 26, 2011 | 04:50 PM
RJ_Moore's Avatar
Car: 85 SC and 87 IROC Both T-Tops
Engine: 305 V8 H Code and TPI F Code
Transmission: 700R AT/OD and 5 Spd.
Axle/Gears: 7.625
Re: Replacement heads, which way to go?
What did you end up doing?
Old Jul 27, 2011 | 02:24 AM
DRock89RS's Avatar
Car: 1989 RS,1991 Z28
Engine: TargetMaster 350, L98 350
Axle/Gears: 10 bolt posi 2.73s, and 3.23s
i would just buy a complete 350 personally.
but if you want to rebuild the 305 then get 305 heads, the 350 heads will
bog the motor down..
Old Jul 27, 2011 | 07:49 AM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
i just rebuild my 305 heads myself and it was crazy
the car did the puff smoke thing since it was 2 years old.
i took it apart... all of the exhaust valve stem seals were gone, and the intake ones were there but hard and brittle and falling apart.
so if your 305 smokes...rebuild it.
the exhaust valves were caked in oil carbon depoists and the car runs soooooo much better now that all the valves are clean and new seals...and all new gaskets of course.
i got a head gasket kit from a place on ebay called reliant gasket.....40$ us for the whole top end gaket kit...CHEAP!
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
BBSDesigns
Aug 11, 2015 07:39 PM
