Power steering pump is WHICH of 2 kinds??
Old Jul 24, 2011 | 11:37 AM
leedavidalan's Avatar
Hey guys I have a 89 manual transmission Iroc-Z. Im gonna buy some stuff and I'm not sure if my stock power steering pump is PRESS FIT or if its KEY WAY.
Do you guys know which one it is for sure??
Old Jul 24, 2011 | 12:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Power steering pump is WHICH of 2 kinds??
Press. This means that the pulley has to be pressed on the shaft (or that a pulley remover has to used to get it off).
Old Jul 24, 2011 | 05:19 PM
Damon's Avatar
Yeah, press fit. It's a smooth shaft with no keyway. Get the proper removal and install tools (2 different tools) and you will save a lot of frustration.
Old Jul 24, 2011 | 09:24 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
yup agreed with the two above if you have a autozone near you can rent the tool from them
Old Jul 27, 2011 | 11:59 PM
thanks guys. you guys never fail
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
beachrodder
Aug 25, 2015 08:05 AM
novaderrik
Aug 10, 2015 12:44 PM
