Coolent leak
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Coolent leak
You don't need a new valve cover gasket because of coolant on the valve covers - there's no coolant under the valve covers!
You need either a new coolant hose, thermostat gasket, or intake gasket. Find the leak first. If needing a new intake gasket, might need new valve cover gaskets if you have to remove the valve covers to get easier access to the intakes removal/reinstall.
