Radiator fan switch, help guys!! please....
Old Jul 27, 2011 | 11:58 PM
leedavidalan's Avatar
hey fellas, i threw out the old 305 fuel injected tpi motor and just dropped a carburated 383 engine into my 89 Iroc. I also removed the stock harnass which controls a ton of electrical stuff i presume. my question, is how do i give power to the radiator fan switch now? also, just as important, WHERE is the switch? any general ideas?
thanks people
Old Jul 28, 2011 | 02:21 AM
Camarobuild18's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI, planning on built 400
Axle/Gears: 2.73 stock axles
Re: Radiator fan switch, help guys!! please....
thanks people
hey there umm the switch was with the harness, where a wire calculated engine temp the computer...
well i just hooked up a toggle switch to my battery, ran it through the whole in the fire wall where the hood popper runs through, and ran it to the fan wires which should be black and red for positive, then ran the other to a good place of ground. ik how much easier it would be to have a electrical thermostat wire
kick it on for you, but you can get a kit that does all that for you by sticking it in to the radiator fins, (sensor) and hooking it all up to the battery or w.e you prefer.
Old Jul 28, 2011 | 02:35 AM
i also forgot to mention my switch lights up in the dash, when i forget to turn it on. When i turn the key on it lights up. Light up toggle, that has three prongs, i simply ran both recieving female and male positives to the switch, (one to positive battery post, then the positive to the fan) and then this third prong had my curiousity. So i hooked it up to my fuse box, where i took the gauges fuse out and rapped the spliced wire around the fuse prong, and the wire ran to the third prong on the switch.. Reason why? I knew that the ignition controlled these gauges, so thus i have a reminder. The light turns off when keys off and the fan is off. But if you leave the fan on, the light will stay on. Hope i didnt confuse ya
Old Jul 28, 2011 | 07:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Camarobuild18
how much easier it would be to have a electrical thermostat wire .
One of these temp switches mounted in the intake or head; connected to the fan wire that used to go to the computer will operate fan at correct temp.
No switch needed , no warning lights needed , nothing to think about
http://www.racerpartswholesale.com/p...n_Accessories2
Old Jul 28, 2011 | 10:55 AM
thanks fellas. i'll investigate all this for sure
Old Jul 28, 2011 | 06:51 PM
vetteoz any tips on tracing that fan wire??
Old Aug 1, 2011 | 10:08 AM
of coarse, its probably located near the thermostat housing or on it or in some different locations.. Im just geussing cause most thermostat housings ive seen from chevy have the sensors and all that
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
TA8487
Aug 16, 2015 12:21 PM
Street Lethal
Aug 14, 2015 08:25 PM
