washer fluid wont spray any ideas?
Old Jul 29, 2011 | 02:19 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
so my wipers work and my washers dont i can hear the motor and it gets warm so i know its working ive tried three different motors and wiper units none of which have sprayed...i blew in all the lines and they aret plugged i primed the line and tried to spray still nothing...any ideas?
thanks TGO
Old Jul 29, 2011 | 03:07 PM
GaryM's Avatar
Re: washer fluid wont spray any ideas?
I fought this on the kids car for some time...and like you swapped several OEM units. My problems always ended up as loss of prime or the pickup tube under the cap falling off. Followed some TGO advice and retrofitted an electric pump last weekend. Also new hoses all the way, new cap, and added check valve in the tank pickup as backup against lost prime. $30 total. Mounted on bracket behind drivers wheel well. I had to dremel out the tubing pass thru holes on firewall a bit, the new hose was thicker wall/bigger dia. Get power from the center electrical connector. On ours the pink was (-) and the two whites were (+) and the plug was brown, but trust your voltmeter. Very happy to have spray not sputter.
heres the Anco pump:
http://www.oreillyauto.com/site/c/de...3297&ppt=C0047
and the McMaster Carr check valve p/n 6079T52 on this page
http://www.mcmaster.com/#plastic-check-valves/=de2j9w
destroyerwes
Aug 26, 2015 08:17 PM
L98GTA87
Aug 25, 2015 02:23 PM
spaigo
Aug 21, 2015 07:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
