having problems with some things
Old Aug 1, 2011 | 10:16 PM
4g63's Avatar
ok first how do you turn the brights on?
2. my power locks stopped working and so did the dome light
3. how the hell do you take the wiper blades off i pressed where it said press but nothing happened and i cant figure it out.....( the only car i had issues with trying to replace the wipers)
Old Aug 1, 2011 | 10:38 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: having problems with some things
....really?
Old Aug 1, 2011 | 11:20 PM
4g63's Avatar
yea im for real i couldnt figure out the wipers.... and ive looked everywhere trying to figure out how to turn the brights on.... and im also trying to figure out why my locks dont work no more
Old Aug 2, 2011 | 08:07 AM
Engine: L31 350
for your brights you pull the light **** near the steering wheel all the way out then pull the wiper arm near you till it clicks.....
Old Aug 2, 2011 | 09:11 AM
WSX123's Avatar
Car: 1988 Trans Am GTA
check the fuse for your locks maybe the fuse popped, but if your locks are working but not sliding back in forth, take the door panel off and use WD40 to lube em up,
Old Aug 2, 2011 | 10:40 AM
Ray the Rat's Avatar
Car: 2010 2RSSS
Engine: 6.2l
Transmission: 6-speed manual
Axle/Gears: 3.45
The dome light and door locks sounds like a fuse. They should be on the same circuit.
Post a photo of the wiper blades. There are several different kinds.
Ghettobird52
Jul 5, 2024 11:18 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bob88GTA
Aug 18, 2015 03:31 PM
sreZ28
Aug 14, 2015 07:48 PM
