fuel problems
Old Aug 4, 2011 | 05:55 PM
TomV's Avatar
fuel problems
After driving my 91 firebird V6 for about 10 minutes and then turning it off for about 15 minutes it won't start, I installed a fuel pressure gauge with a bled line, the fuel pressure is about 39psi but when I relieve the pressure thru the bled line the fuel has bubbles and is very hot. Also the fuel return line is very hot, what could be the cause of this problem?
Your help would be appreciated!!
Old Aug 5, 2011 | 05:35 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: fuel problems
hi tom.
these people in the two links below have had similar issues. may be something helpful in here for you.
https://www.thirdgen.org/forums/tpi/...hing-else.html
https://www.thirdgen.org/forums/tpi/...regarding.html
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
