low miles 305 cam swap
Old Aug 8, 2011 | 02:28 PM
musclecarguy91's Avatar
Car: 91 Camaro Z28
Transmission: auto
I have a 305 with roughly between 3,000- 6,000 miles on it. Would the cam bearings need to be any machine work done to it in order to put a new cam in it?
Old Aug 8, 2011 | 08:18 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: low miles 305 cam swap
well.... it's a matter of choice I guess. If the cam that is in it is removed carefully as to not scar them up any, you are probably ok not replacing them.
Old Aug 8, 2011 | 08:46 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I've done 2 cam swaps on the same cam bearings, with a helluva lot more than 6000 miles on them. Looked at em with an endoscopic camera last time, a little coppery at the bottom, but the oil pressure was and still is what it should be. I'll do them when/if it becomes necessary to pull the motor.
Old Aug 9, 2011 | 06:41 AM
Cam bearings, probably OK, if undamaged.
Any other machine work, impossible to tell without knowing what the motor is (part #s only please), what cam you want to put in it (by part #), and having MEASUREMENTS of the rest of the motor.
Old Aug 9, 2011 | 05:35 PM
Car: 91 Camaro Z28
Transmission: auto
I don't know the exact specs. When I bought the car a few years ago the guy said there is a new jasper 305 in it.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
