starting issue
Old Aug 9, 2011 | 04:34 PM
rudedog's Avatar
Car: 1987 iroc
Engine: zz4 350
Axle/Gears: borg warner 9 bolt 3.70 gears
starting issue
hi , i have 11.6 volts on my battery and it won't crank at all. it seems to me that should be enough to crank it over slowly but i get nothing.lights come on but no cranking at all. put jumpers on and it fires right up. do i need more juice or is it possible my starter could be going requiring more volts? this has happened before when i let it sit for awhile without starting. it just seems to me 11.6 should crank it slowly. once i run it and there is 12+ volts it starts right up.
Old Aug 9, 2011 | 07:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: starting issue
It's not the volts as much as the amps. 11.6 is telling us the battery is drained some, but not to what degree - the amps tell the real tale - at 11.6 it's quite possible the battery just doesn't have enough amps (ie grunt) to start the car.
Old Aug 9, 2011 | 11:18 PM
wolverine350r's Avatar
Car: 91 TA WS6
Transmission: Auto :(
Re: starting issue
Take the battery to the parts store and have them load test it, I bet its toast.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
