What do I need to lower my IROC?
Old Aug 9, 2011 | 11:42 PM
leedavidalan's Avatar
Hi guys I have an 89 Iroc, manual tranny. It used to have its stock tpi 305 but we recently threw that out (along with most of the a/c and heating components) and just finished installing a carburated 383. Today we took the car off the jack stand and noticed that the front end sticks its nose up about 3 to 4 inches higher than before. The new engine must be much lighter than the old.
My question, WHAT do I need exactly to lower the front end to where it used to be? Im guess 3 inches total in the front, and the back im not so sure it needs lowering at all.
Thanks fellas!!
Old Aug 9, 2011 | 11:47 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: What do I need to lower my IROC?
3-4 inches higher! not a chance. I imagine its slightly lighter with aluminum parts ect. but....
The springs/shocks just have to settle, give it a nice heavy jounce. Also make sure springs are seated correctly.
If its still a couple of inches higher or even really 4" like you say, drop spindles in combination with lowering springs. Suspension geometry will be off.
Old Aug 9, 2011 | 11:49 PM
yeah it really is significanly higher than before. we have a table on the side full of stuff that was not reinstalled. thanks for the advice!
Old Aug 9, 2011 | 11:51 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Springs did not settle right.
Old Aug 9, 2011 | 11:55 PM
Car: 1985 IROC-Z
Engine: 355
I don't care if you took out 200lbs worth of stuff it would not sit 4" higher. There is something else wrong.
Old Aug 10, 2011 | 12:02 AM
thanks sooo much for the help guys. in a couple days when i resume working on the car i'll see where it sitting at.
italiano67
Dec 11, 2016 09:21 AM
87iroctheo
Dec 4, 2016 11:47 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
mustangman65_79
Aug 11, 2015 03:17 PM
