is a smog pump eliminator bracket worth it?
Old Aug 10, 2011 | 11:03 AM
musclecarguy91's Avatar
Car: 91 Camaro Z28
Transmission: auto
Has anyone purchased this smog pump eliminator bracket? And is it worth the 50 bucks? http://www.summitracing.com/parts/NAL-10129569/
Old Aug 10, 2011 | 11:57 AM
Guest
Guest
Posts: n/a
Re: is a smog pump eliminator bracket worth it?
Why? You're saving maybe 5 pounds, you're gaining 0 HP, and you're rendering the car technically illegal. But removing it does reduce clutter a bit.
Old Aug 10, 2011 | 12:18 PM
Car: 91 Camaro Z28
Transmission: auto
From what I understood it reduces power, whether that is true or not I have no idea.
Old Aug 10, 2011 | 01:32 PM
torque_is_good's Avatar
is it worth it is a very loaded question. If you are just looking at a hunk of aluminum and a wheel then heck no it isn't worth $50.
But, what Summit knows is that if you remove the AIR pump, you then need a different serpentine belt which is anywhere form $35-$45 for the belt. You also must re-route your belt.
So, they figure that you would spend $50 to retain your stock belt and stock routing of said belt.
Old Aug 10, 2011 | 03:34 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you're set on pulling the pump and want another option (new belt) take a look here:
https://www.thirdgen.org/serpentine
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
evilstuie
Apr 14, 2016 08:52 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
