Motor sitting crooked
Old Aug 16, 2011 | 08:37 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just installed new motor mounts in my car before putting the new motor in and now as I am going to install the tranny I noticed that the motor is sitting lower on the drivers side. What could be wrong?
Old Aug 16, 2011 | 07:54 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Motor sitting crooked
do you have the bolts in each mount? Its possible that the drivers side is seated while the passenger side is hung up
Old Aug 16, 2011 | 08:22 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yes, both bolts are through the mounts.
Old Aug 16, 2011 | 08:45 PM
tjtaylor's Avatar
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
sure you dont have to motor mounts flipped? they do matter, one offsets the block so depending which one you put were it'll matter
Old Aug 17, 2011 | 12:05 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Exactly.
Old Aug 19, 2011 | 04:24 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I checked and the mounts are on the correct sides.
pfsteichen
Feb 9, 2016 06:59 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Justin92GTA
Aug 27, 2015 11:16 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
