transmission problems
Old Aug 18, 2011 | 09:09 AM
67 RSSS camaro's Avatar
Car: 87 camaro
Engine: 2.8 v6
I have a 87camaro with a v6 2.8 in it. i have noticed that it will not shift to fourth unless its cool outside but after about 10 minutes of driving it will down shift back to 3rd. i can not figure out why if you have any ideas please help
Old Aug 18, 2011 | 09:51 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: transmission problems
sound like it may be low line pressure. may be because of old fluid? my first step would be trans flush and filter.
Old Aug 18, 2011 | 10:00 AM
Car: 87 camaro
Engine: 2.8 v6
i got it flushed 5,000 miles ago. the last time i checked it was low so i filled it up to the line after that it would shift to fourth but only for a little while. as you stated above "it may be low line pressure" could it be burning trans fluid?
Old Aug 18, 2011 | 10:37 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
unlikely to be burning fluid. have you checked your coolant, trans fluid may sometimes leak between the integrated trans cooler and the radiator. im guessing you have no visible drips or puddles in the driveway.
Old Aug 18, 2011 | 02:20 PM
Car: 87 camaro
Engine: 2.8 v6
thank you for your help we pulled the transmission out and the pump was going bad. now it runs like a champ
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
