Vacuum line help
Old Aug 22, 2011 | 05:56 PM
Jcase350's Avatar
Car: 90 Camaro Iroc-z
Vacuum line help
I have a 90 camaro 350 TPI. There is a small vacuum line located underneath the throttle body. Can anyone tell me where that vacuum line and also the one located on the MAP sensor is supposed to go? Thanks in advance
Old Aug 22, 2011 | 07:09 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Vacuum line help
that is the egr solenoid vacum line. Goes from throttle body to egr solenoid. I think it is the front connector of the two on the solenoid , the other hose from the solenoid goes to the egr valve itself. The map sensor's vaccum line goes from the map sensor to a nipple on the side of the plenum.(on the passengers side).
Old Aug 23, 2011 | 05:44 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
here is a vac line diagram. hope this helps
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
