Street and Strip Oil Pan
Old Aug 24, 2011 | 06:51 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
Im about to pull the trigger on a oil pan for my 383 build. I came across cantons drag race pan #13-080t after narrowing down the search on summits website they show it to work on our cars, I called canton's tech line and the guy there seems to think it should work. This is a 6qt pan with built in windage and scraper for 200 bucks. I have long tubes so im not worried about hitting a Y-pipe! what you guys think??
The link
http://www.summitracing.com/parts/CTR-13-080T/
Old Aug 25, 2011 | 04:05 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Street and Strip Oil Pan
I don't know about that one, but Moroso sells one specifically identified for our cars which is a 6qt oil pan and bolts right in with no issues unless you have a factory Y-pipe, which you'll have to have a shop modify to fit aorund it. I didn't find this out until I installed the motor, must to my disgust. So I ran open header from where I installed it, 18 miles to the exhaust shop. Got some good looks on that. Did melt my starter wires though.
Old Aug 25, 2011 | 05:01 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Unless you get crazy with the cheese whiz, kiss your Y pipe goodbye with the Canton pan. There is no room between the K member and the pan for a Y pipe, and if you go in front of the pans sump, the Y will go under the K member, and hang lower than the pan. Long story short, I installed that one last winter, and it motivated (forced) me to scrap my entire exhaust. And 700r4 .
86CamaroDan
Sep 29, 2015 10:08 PM
fasteddi
Sep 10, 2015 09:32 AM
Gunsbee
Sep 7, 2015 07:10 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
