Good looking?
Old Aug 25, 2011 | 01:00 AM
formulax4's Avatar
Car: 87 GTA
Engine: Two cracked out gerbils
Transmission: 700r with a probuilt automatics kit
Good looking?
Now that i got your attention please comment!
First oilchange on the new engine build,less than 25 miles but about an hour of run time :/ This is what the oil looks like...
http://i265.photobucket.com/albums/i...s/SN852354.jpg
http://i265.photobucket.com/albums/i...s/SN852353.jpg
I looks like a aweful ammount of metal in there to me.. What do you guys think?
Old Aug 25, 2011 | 01:21 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: Good looking?
Can see it to well on here but it doesn't look so good
Old Aug 25, 2011 | 08:20 AM
Dougs91's Avatar
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
Re: Good looking?
By what I can see in the pics, it makes me wonder if block was cleaned after any machine work was done. Looks like alot of flushing and filters to clean it out. I would even put a magnet on the filter to help catch all you can. Good luck!
Old Aug 25, 2011 | 08:41 AM
formulax4's Avatar
Car: 87 GTA
Re: Good looking?
Yeah it was cleaned well after machineing.I used my 1800psi power washer and even mild soap.I do that after getting every block back.Made sure to spray out all the oil galleys as well.I had to wipe dry the cylinders and main bores so they could be oiled quickly.But the rest got blown out with compressed air and quickly coated with WD40.
I used the old roller lifters and cam they were in nice shape from looking and measureing them.Im a little bummed out here.Ima change the oil out couple more times and run it for another hour or so while keeping a good eye on the oil.The next time i change the oil if its like this i think ima yank the engine and inspect everything again.Its sure sucks to have to replace the rods mains and cam berings again thats for sure,not to mention the oil filter gaskets and labor.
Old Aug 25, 2011 | 07:48 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Good looking?
Magnetic sump plugs are a good idea to help pick up pieces of metal floating thru the oil.
If in double, take the oil filer out and cut it apart to see what it has picked up.
I have a small plane and always cut the oil filter apart after changing it to get an idea if there are any problems with the engine.
Typically, cam shaft lobes are the first engine component to start shedding metal.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
