rpm gauge
Old Aug 26, 2011 | 12:13 AM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
rpm gauge
hey, i couldn't find a forum for this question so im asking here. i have a 90 rs with 305 t5. as most of you know, the gauge cluster is basically crap. my trip quit working after i tried to reset it one day. since ive owned the car the idle always seemed a little to high. idle is about 1500. when im cruzing at 70 mph my rpm says im doing 5k. which is a jump since i bought the car, it use to read 4500. either way i knew something was wrong. what im basically asking is if anyone can tell me the speed your going per gear when you hit redline. only reason im asking is because, well.. i want to know when my engine is going to red line! lol thanks.
Old Aug 26, 2011 | 12:20 AM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: rpm gauge
Every car is different.
Old Aug 26, 2011 | 12:23 AM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Re: rpm gauge
yes, im not asking for like the exact speed. just a general speed. like dont go over 40 in 4th gear or something. just so i have an idea.
Old Aug 26, 2011 | 11:38 AM
Dougs91's Avatar
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
Re: rpm gauge
Look in electronics for the sticky "90-92 tach fix". This will help you out and not have to guess what RPM your're at.
Old Aug 26, 2011 | 03:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: rpm gauge
I've got the same engine and trans you have. When I'm going down the freeway in 5th gear,at 73 mph I'm turning about 2000 RPM, so practically lugging it unless I'm in fourth. When you're cruising at 70 in fourth, you're turning about 3000 RPMs
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
