hesitation only at part throttle
Old Aug 30, 2011 | 10:38 PM
chevy77's Avatar
Car: 1977 nova rally
Engine: 89 tpi 305
89 tpi 305 ive put new injectors in since i found a bad one replaced the cts swapped the maf with a known good one replaced the knock sensor it tested bad the timing is right at 6* fuel pressure is 45psi tps is at .54 key on engine off
it starts hard only when cold it fires right up then dies it does this 5 or 6 times before it will stay running then while driving light throttle it always tries to die the only way i can get it down the road decent is if i floor it this has me lost im running out of money and things to test
anyone have any ideas
Azrael91966669
25
Jun 20, 2017 04:04 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
