Will this be ok for a daily driver?
Old Sep 1, 2011 | 02:31 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
A L98 block, patriot vortec style heads a lt4 hot cam and HSR with a tune. Will this be ok as a daily driver? compared to a stock L98? I want to build the motor for my car but as of now my car is all I have to drive. I just want to know if I build the engine and then swap it in if I still would be able to drive this car every day and how much different the low rpm drivability and mpg be? With a wc t5 and 3:42 gear.
Old Sep 1, 2011 | 02:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Will this be ok for a daily driver?
well tuned it should drive just fine with just alittle cam lope to know its not stock, and still get decent mileage depending on how you drive and how well its tuned.
Old Sep 1, 2011 | 03:00 PM
Engine: 350 for now
Transmission: wc t5
That's good to hear. And I drive pretty easy most of the time. When no one is around I hammer on it but thats maybe once a month. But I was worried about the mpg and drivability because I this is my only car but at the same time I don't want to build a engine i'm not happy with. I have a stock 350 now thats on it's last leg, just looking for more hp but still able to drive it to work.
Old Sep 1, 2011 | 03:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Becareful with the swap if the motor is on its last legs. Whats wrong with it? Drinking oil? Rings may be worn and it may have low cranking compression as it is, so with a bigger cam its gonna feel alittle lazy down low but shouldnt be too bad. If you can shave the heads down some to bump compression, that would help alittle with that cam but it doesnt need more. Lots of guys run LT4 hotcams on mostly stock motors and love the power it makes.
Old Sep 1, 2011 | 03:40 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Idk about the parts, but in my experience you don't want to tear into the motor if you don't have a backup car to drive in the meanwhile, take my word for it.
Old Sep 1, 2011 | 03:47 PM
Engine: 350 for now
Transmission: wc t5
oh, I'm sorry I should have explaned more. I'm going to build the hotcam motor from a newly machined and rebuild L98 short block. Not the l98 thats in the car. The plan is hopefully the car will drive long enough to finish the other motor so I can take my vacation from work and then swap the engines. But the motor in the car is knocking slightly and burning oil pretty bad. So I baby it hoping it don't brake. the knocking is coming from the bottom end somewhere. I know its not exhaust leak or valve lash I have checked and rechecked those (new manifold gaskets and set the valve lash and checked 3 times) plus stick a screw driver to the oil pan and your ear to the screw driver handle and you can here the knock very very very good.
But the stock bottom end and making good power is why i chose to go with the hotcam. I have read a lot of good things about them in street cars.
Old Sep 1, 2011 | 04:09 PM
Engine: 3.8, 3.4
Hmm, well plan 3-7 days for the swap to account for complications, especially if you haven't swapped an engine before, I mistakenly bolted my engine block to my transmission bellhousing with the torque converter not fully engaged....had to pull the trans to make sure I didn't screw up the front pump, I guess its not all that uncommon a mistake from what I'm told. But now I know to put the TQ converter on the transmission side first, its a lot easier and less room for mistake...
Old Sep 2, 2011 | 09:17 AM
Engine: 350 for now
Transmission: wc t5
Just curious, what kind of fwhp and whp would I bee looking at with this set up?
Old Sep 2, 2011 | 09:39 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I would guess somewhere near 300whp-320whp if all goes well on a good bottom end.
Old Sep 2, 2011 | 09:46 AM
Engine: 350 for now
Transmission: wc t5
wheel hp? wow that will be plenty. I'ed be more than happy with that.
Old Sep 2, 2011 | 09:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Most hotcam setups with somewhat decent heads will do 300-320whp from what I've seen on here. Stock L98 heads with ported stock base, stock runners made 275whp, so complete aftermarket better flowing intake setup should easily add 25whp. I know bolt on TPI stuff on L98 vette heads will do 320whp from what was posted here a few years back.
Old Sep 2, 2011 | 10:40 AM
Engine: 350 for now
Transmission: wc t5
Awesome, I plan on using a HSR and patriot performance vortec style heads. So I should be in the 320 range
Old Sep 2, 2011 | 10:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah, I think its quite possible, especially through a T5 tranny since manuals have less loss than an automatic.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
ramicio
Sep 28, 2015 01:18 PM
BWilcox
Sep 20, 2015 12:19 PM
david068513
Sep 18, 2015 10:36 AM
rsrookie
Sep 5, 2015 07:08 PM
