AFR coolant plug
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
AFR coolant plug
I am trying to plug up the coolant hole on the back of the passenger side of my AFR head. The 3/8" plug that I am trying to use doesn't go all the way in when its tightened. Does anybody know what size this plug is?
Engine: 4++,350 & 305 CIs
Re: AFR coolant plug
its the same as the one on the driver side front,NPT so its tapered and probly wont set flush when tightened. dont forget thread paste.
Car: 85 Iroc-Z
So as long as I tighten it and put teflon tape on the pipe plug I shouldn't have any problems?
