Slightly erratic Idle, im thinking Ignition
Old Sep 8, 2011 | 10:12 PM
Deluca119's Avatar
My car has and still is running like a champ. Recently like 2 to 3 weeks ago the tach started jumping around, it was always inaccurate though, eventually i got a good deal on an autometer tach that I installed yesterday. This tach is reading the correct range however has the same symptom of jumping around and reading a little erraticly. The car does shudder just slightly somewhat often in drive with no gas.
I took of the cap and cleaned up the ICM which I recently replaced during my tune up around 2 months ago. It doesnt look like it did much the cleaning but i figured it couldn't be worse. I should note that my dizzy cap is just a little loose because the rear bolt broke, im going to get another bolt tomorrow to eliminate that. The wires came with the car in a box and appear to be in good shape and it wasn't doing this when I initially got the car running.
Im thinking if I can find a MSD blaster direct replacement at the right price ill throw that in with a msd cap and rotor. But i dont want to put any money into a 305. I have witnessed the car arcing also at one point, it was arcing to the coil, perhaps that fryed something? Thanks in advance, I tryed to describe everything to the best of my ability.
midge54
Jan 29, 2017 07:00 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
