What transmission fluid should I use??
Old Sep 9, 2011 | 06:41 PM
leedavidalan's Avatar
Hey fellas just wondering what kind of transmission fluid I should use. I have an 89 Iroc, manual tranny, 5.0 V8 305.
I'm assuming if I walk into autozone there will be more than one kind, thats why I ask.
Thanks guys!!
Old Sep 9, 2011 | 07:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: What transmission fluid should I use??
https://www.thirdgen.org/forums/tran...synthetic.html
Old Sep 10, 2011 | 02:28 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Standard automatic transmission fluid is whats called for with the T-5 for every day driving. For the ATF, stick with the standard dex/merc III. Ive found that, with my TKO at least, the synthetics cause issues with the syncros due to the higher film strength. Causes the trans to take an excessive ammount of time to syncronize.
Old Sep 10, 2011 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a sticky that may amaze and/or confuse you even more:
https://www.thirdgen.org/forums/tran...ything-we.html
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Numbah-1
Sep 12, 2015 08:57 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
