305 TPI Upgrades
Old Sep 12, 2011 | 05:52 PM
capj66's Avatar
Car: 1987 IROC
Axle/Gears: Borg Warner 9-Bolt Disc 2.77
305 TPI Upgrades
Hi all kinda a newby here so bear with me. My son and I are restoring a 87 IROC on the cheap.
The engine is stock 305 TPI but there is a bad lifter in there, (No sound when it's cold but when the
engine gets to operating temp there is a rap/knock coming from the down tubes under the intake).
So since I have to tear down the top end to fix it this is what I was thinking of doing to get a little
more out of the engine:
1) Install used 1988 L98 Roller cam and lifters from a low mileage motor
2) Install new Comp Cam springs and retainers
3) Install new valve seals
4) Install new 1.6 roller tip rockers
5) Install new Comp Cam High Energy pushrods
6) New double roller Timing chain and gears
7) New water pump
8) Clean up the inside of the throttle body, plenum, runners to get rid of excess so that it can flow better
9) Install a set of Pacesetter Carb Legal 1-5/8 2-1/2 out headers w/air tubes
10) Install Magflow 2-1/2 in-out Hi flow cat
11) Install Dynomax 17495 - Super Turbo Kit; Cat-Back System
Most of the above items I have been able to scrounge up cheap so I guess my question is will this all work together
and is it reasonable to expect to get 30hp to 40hp gain.
Car Specs: 1987 IROC T-Top 305TPI (stock) 700R4 (stock) 9-bolt Borg Warner with 2.77 and discs.
This car is not for racing or 1/4 mile times just for pleasure driving around town and on a few trips when
the weather is nice.
Any and all recommendations and assistance is greatly appreciated.
Thanks Jim in CT.
Old Sep 12, 2011 | 06:18 PM
ex-x-fire's Avatar
Re: 305 TPI Upgrades
Just make sure you find the noise before spending alot of money on the engine.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
