Oxygen Sensor
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Oxygen Sensor
I have been looking online for an Oxygen Sensor for my 82 Firebird. I live in Ireland so have to get it mail order from the States. I believe all the Thirdgens use the one wire sensor (but could be wrong!) which I think is an SG5 type. Here is the thing, I look at one site for one that fits my car, say a Bosch 12014 but when I look at another site it says this sensor is not compatable. The sensors I looked at all have the correct connector on them. Does anyone know is the SG5 sensor correct for the Thirdgens. Don't want to order one, find out the ECM doesn't like it and have to wait over two weeks for another one to arrive.
Thanks.
Thanks.
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Oxygen Sensor
From the pics # 12014 Universal O2 Sensor for GM looks like the O2 sensor used on most GM cars to '90 at least
CHEVROLET
1985-91 Astro Van (L, M Series)
1987-96 Beretta, Corsica
1983-94 Blazer (C, K, V Series)
1983-91 Blazer, Trailblazer (S Series)
1980-95 Camaro
1982-98 Cavalier
1982-90 Celebrity
1980-87 Chevette
1980-85 Citation
1982-93 Corvette
1980-87 El Camino
1980-93 Impala, Caprice, Bel Air, Biscayne
1987-95 LLV (Postal Vehicle)
1990-95 Lumina APV
1980-98 Malibu, Chevelle, Laguna
1992-94 Metro
1980-88 Monte Carlo
1980 Monza
1983-95 P Series Truck
1983-95 Pickup (C, K, R, V Series truck)
1982-98 Pickup (S, T Series)
1985-88 Spectrum
1987-91 Sprint
1983-95 Suburban
1995 Tahoe
1983-94 Van (G Series)
Engine: 2.8 V6
Re: Oxygen Sensor
Hi,
I will go with the Bosch one 12014. I could try and sourse one, hopefully I can find one.
Thanks for your help.
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Engine: 2.8 V6
Re: Oxygen Sensor
I went for a standard one in the end as that was cheaper postage to Ireland. The bosch is an equivilent part. The ECU ignores the O2 sensor until the engine reaches operating temperature. So you should know after 5 - 10 minutes. Can be a bitch to get these out if they haven't been changed in a long time.
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Oxygen Sensor
As long as its the right part I should be able to switch it in, thanks for the reply
HoosierinWA
Oct 7, 2015 10:15 AM
