vibration
Old Sep 18, 2011 | 09:19 PM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
vibration
Now onto issue 2.
My camaro vibrates when i give it a little more gas about medium throttle however is fine under full throttle or if i granny it any suggestions. (Universal joints are brand new and did not change this vibration at all)
1991 Camaro Z/28 V8 &700R4 Transmission
Old Sep 18, 2011 | 10:05 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: vibration
Look for dents in the drive shaft, maybe get it re-balanced.
All tires in good shape-- slipped belts, high miles?
Check the harmonic balancer for ring slippage.
Check the flex plate bolts are tight.
Check suspension & drivevtrain mounts are tight.
Vibrations while in idle, driving, or both?
Old Sep 19, 2011 | 08:30 PM
Engine: 5.0L 305
Re: vibration
Vibration only noticeable while drving in gear if it vibrates when i rev it it is not noticable
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
