no spark
Old Sep 20, 2011 | 12:39 AM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
no spark
i have a 1988 iroc tpi 5.7ltr this morning i turned my car on, and as i was warming it up all of a sudden it turned off, i tried turning it on again and nothing. so i check for spark and ZERO spark at the coil. ok so i buy a coil, ignition module and still no spark. next day i say screw it im buying a rema dist. as i was taking off the old dist. i noticed that the pick up coil was all broken. so i figured that would be the problem so the dist i bought came with everything from the ignition module to the coil pick up. i install new distributor, and still no spark. so im going crazy trouble shooting this. i really appreciate any feedback. thanks for the help in advance. pls email me as im using my neighbors computer, but i have an android phone which i receive email. saldav420@gmail.com
Old Sep 20, 2011 | 07:34 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: no spark
Have you got 12V at the coil Pos +?
Old Sep 20, 2011 | 09:50 AM
1killerolds's Avatar
Re: no spark
agree with vetteoz, check for power at the coil, then try wiggling the connector on the coil why trying to start. I had an intermittent stall/no start on a fireturd that ended up being the terminals were loose in the two-wire coil connector.
Old Sep 20, 2011 | 10:26 AM
saldav420's Avatar
Transmission: 700r
Re: no spark
How do I test for 12v? could someone explain in simple English, going to be trouble shooting it some more today. any other help will be highly appreciated.
Thanx you guys ROC
Old Sep 22, 2011 | 07:39 PM
85 Frankenstein's Avatar
Car: 1985 Camaro Z28
Engine: 1988 305 TPI
Transmission: 1993 T-56
Axle/Gears: 3.08
Re: no spark
The two wire plug that plugs into the ignition module from the coil, unplug it, turn the key on, you should get 12 volts at both terminals.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
