several questions
Old Sep 20, 2011 | 07:36 PM
russ89gta's Avatar
Car: 1989 pontiac trans am gta
Engine: tpi 5.7
Transmission: th700r4
several questions
I have my new engine in my GTA and am just about ready to fire it up. However, over the weekend I had to pull the plug wires from the distributor cap. I had a diagram that showed what order they go on, but I have misplaced it. Could sombody tell me what order the wires go in on the distributor cap?
Also, the car has sat for about a year with the new engine in and has not been cranked during that time. Should I change the oil before firing it off, and if so, do I need to pull the distributor and prime the engine?
Thanks for the help. I just don't want to hurt my new engine. It cost plenty!
Old Sep 20, 2011 | 07:39 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: several questions
i would prime it but you need to pull the fuel pump relay if your gonna prime it, anything over 5psi and im pretty sure the fuel pump kicks in. http://pichollywood.blogspot.com/201...ing-order.html theres the firing order
Old Sep 20, 2011 | 07:44 PM
russ89gta's Avatar
Engine: tpi 5.7
Perfect! exactly what I was looking for!
Is it absolutely necessary to prime it?
Old Sep 20, 2011 | 07:47 PM
Car: 1990 camaro RS
Engine: 305 TBI
idk ive never swapped engines in a car, ive always read to prime it though
Old Sep 20, 2011 | 07:54 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
its not necessary but always a good idea to prime it, 1st it will tell you your going to have good oil pressure and it will fill the oil filter so you dont have a dry start (everything will have a nice coat of oil on it so no metal on metal) but like I said its okay to do it with out priming if it sat for a year change the oil as it will turn acidic over time and also contain moisture.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
